utiliser linknx
pb d'nstallation
la librairie est pthsem est bien installer cependant j'ai ce message
d'erreur:
| Found pthsem 2.0.7 under /usr/local, but
| was unable to perform a sanity execution check. This usually
| means that the pthsem shared library libpthsem.so is present
| but $LD_LIBRARY_PATH is incomplete to execute a Pth test.
| In this case either disable this test via --without-pth-test,
| or extend $LD_LIBRARY_PATH, or build pthsem as a static
| library only via its --disable-shared Autoconf option.
| We used the following build environment:
| CC="gcc"
| CFLAGS="-g -O2 -I/usr/local/include"
| LDFLAGS=" -L/usr/local/lib"
| LIBS=" -lpthsem -ldl -lnsl"
| See config.log for possibly more details.
quelqu'un a une idee????
utiliser linknx - par kervy - 31/01/2008, 22:38:18
utiliser linknx - par jef2000 - 31/01/2008, 23:22:35
utiliser linknx - par kervy - 04/02/2008, 20:05:35
utiliser linknx - par kervy - 04/02/2008, 21:52:57
utiliser linknx - par jef2000 - 04/02/2008, 22:54:47
