J'ai fait décharger et téléchargement complet (adresse + application) si c'est ça que tu évoques ?
Je n'ai pas su réaliser la Master Reset
Voici la réponse de JUNG :
First of all, I have to know which ref.-no. is affected, because we have older and newer models od a F40 2-gang push-button. A screen shot of the device features in the ETS would help as well as an image of the laser print on top of the module.
I assume, you have used the wrong data base version to the existing firmware of the module you are using.
If you think everything should be OK, you might isolate this particular push-button from the bus and try to program it straight with the PC over an interface without any other device/line.
Attached, please find the changelog file for the actual version LS 4292 1ST.
